Throwing the following codes - P0135, P0172, P0401 (current stores code)
Following codes are from a reader that reads OEM GM ENHACNED codes labeled as FCS codes.
P0135:
Heated oxygen sensor (HO2S)
Heater Performance Bank 1 Sensor 1
P0172:
fuel trim system rich bank 1
P0401: this was the only code that was “stored”, it was the one that made the SES light turn on.
secondary air injection (AIR) system
first 2 codes I have no idea why they are on or what they refer to other then a googled description. The last code 0401 I’ve seen is just a typical tune of the computer to remove the AIR system, is this correct? I would as well have the EGR system removed. I have long tubes with an off road y-pipe no cats or no muffles with it dumped at the end of the driver side door.
thoughts?
just recently did MSD OTVC 8.5mm wires with NGK TR55-ix plugs, removed AIR, wrapped all the connectors from the pump into the harness. New mad coil, only fuel related thing I did was added raxetronix harness upgrade and wrapped some fuel lines by the y pipe.
thanks in advance for your help!
P0135:
P0172:
thoughts?
Both sensors have less then 3,000 miles on the combined. Both are oem parts from GM parts direct. I’m using front O2 extensions from WS6 store for a simple plug and play connection. I can try swapping the sensors with new ones, I’ve also seen a improperly mounted MAF sensor could cause it (meaning it’s backwards but I’m certain I have it right of all things but I’ll doubke check).
