LT1 383 stroker HP numbers
Old Nov 1, 2017 | 01:20 PM
Joe Soucy's Avatar
Default LT1 383 stroker HP numbers
hi i was wondering how much hp people are putting to the wheels with an LT1 with a 383 stroker kit/Ported heads/Decent size Camshaft.
The set up im going with is the SCAT rotating assembly, 383 forged pistons and rods with cast crank. ported heads, custom 236/242 110 LSA camshaft, 1.6 rr's, etc...
im just wondering what kind of numbers that might put down to the rear wheels.
thanks
Old Nov 1, 2017 | 01:45 PM
BALLSS's Avatar
assuming the "etc" includes headers, larger injectors & TB, TUNE....about 400ish +/-
regarding your parts list....get a forged vs cast crank
Old Nov 1, 2017 | 02:03 PM
MEAN LT1's Avatar
Unfortunately, the above is true. You would think we would have stepped our game up by now. Everybody seems to be ok with making 400hp motors. *sigh*
Old Nov 1, 2017 | 02:15 PM
Puck's Avatar
Not everyone!
Just hard to spend the kind of money needed to make big numbers with a 383 on an aging NA LT1 platform when insane numbers can be had for less by going boosted.
Old Nov 1, 2017 | 02:35 PM
MEAN LT1's Avatar
Originally Posted by Puck
Not everyone!
Boosted...I keep wondering if that's the ticket. But Ive been down that road and it snow *****. A decent Procharger kit new is around 7k. Yea...you can buy used for half the price but still gotta upgrade injectors, big fuel pump, big intercooler and gauges.
Maybe I got away easy with my build. My current build makes about 440 to the wheels and its a 355. The only part I purchased brand new were the heads and pistons. Everything was used. I love when I see people put there stuff up to go LS. Puck, I hear what your saying. Im just tired of seeing the same old thing. I know you are too.
Old Nov 1, 2017 | 02:44 PM
Shownomercy's Avatar
Man-Crush Warning
Anyone who thinks the jump from 400 to 700 or whatever is simple, should stick with 400hp reliability.
Old Nov 1, 2017 | 02:57 PM
SS RRR's Avatar
Village Troll
Can't really reinvent the wheel when the platform has been around for over sixty years.
Old Nov 1, 2017 | 03:16 PM
MEAN LT1's Avatar
And yet people are still using hot cams, cc 305, 306..etc. Cams that have been around since the early 90's. Not looking to reinvent the wheel but technology has moved forward. Its like when I hear people say Solid rollers need to be adjusted all the time. No they dont...its old school mentality.
Old Nov 1, 2017 | 04:06 PM
SS RRR's Avatar
Village Troll
LOL, those cam grinds have been around a lot longer than the 90's...
It's not the cams that are the issue, but the head design. There's only so much you can do before you plateau. As far as adjusting with SR, I have no idea how long shaft mount rockers have been available, but with an aggressive SR, that's about the only way you don't have to adjust. I ran a mild SR with stud mount rockers and did have to adjust periodically.
Pretty much everything that can be done to a SBC has already been done in some form or fashion. The next generation with its superior head design is where it's at.
Old Nov 1, 2017 | 04:18 PM
AnotherWs6's Avatar
^^^^truism, truism
Old Nov 1, 2017 | 07:37 PM
z28jimmy's Avatar
Just had my motor built.. check out the build info and numbers.
https://photos.app.goo.gl/my356mbTOGvFWocK2
Old Nov 2, 2017 | 07:59 AM
MEAN LT1's Avatar
That combo ran out of steam quick. Power started dropping off by 6100. What did the graph look like?
Old Nov 2, 2017 | 10:20 PM
z28jimmy's Avatar
510hp at 6100rpms I didn't think we bad? Is that not good for a built LT1? There was no graph just the numbers your seeing on the paper. I'll be getting Dyno Numbers shortly.
Old Nov 2, 2017 | 10:30 PM
Ed Wright's Avatar
9-Second Club
537 rwhp, 383" LT1. Nearly ten years ago.
More knowledge & better parts available now.
Old Nov 2, 2017 | 10:32 PM
KW Baraka's Avatar
That's an engine dyno.....yes? Not bad.....but peak power should be around 6300 RPMs with that cam.
Did they say anything about the headers they used?
KW
Old Nov 2, 2017 | 10:36 PM
z28jimmy's Avatar
KW
Correct it is an engine Dyno. Im not sure what headers were used.
Old Nov 2, 2017 | 10:42 PM
KW Baraka's Avatar
Correct it is an engine Dyno......
Yep.....silly me.
Forgot that I'd seen that in your build thread
KW
Old Nov 3, 2017 | 02:13 PM
Joe Soucy's Avatar
What RPM do u shift at with this cam ?
Old Nov 3, 2017 | 03:06 PM
z28jimmy's Avatar
Juat wrapping up the install and getting it tuned on the 14th.
Old Nov 7, 2017 | 11:30 PM
sixt9er's Avatar
Thinking of building a low budget, 383 LT4 based stroker for my 1995 Impala SS. I use the term "low-budget" because i have collected the majority of the parts over the last 10 years, from folks upgrading to LS-based engines. I'm not looking to race or make 500 horsepower, but I am looking for a solid, 400 ft. lbs. of torque, with a noticeable idle, reliable enough for highway cruises and decent street manners.
I already have LT4 heads and intake and HOT cam. Most likely will not use HOT cam, as this heavy vehicle will retain the automatic transmission. New engine will have the basic performance upgrades like, headers, new Opti, throttle body, roller rockers, tune to maximize performance, etc. Other vehicle upgrades will include replacing the 3.08 rear gears with a 3.73 gear set.
I'm in Cali, so this vehicle must pass the state SMOG/emissions test.
