Help with compression math
Old Nov 9, 2017 | 04:58 PM
AdsoYo's Avatar
Default Help with compression math
I'm working on getting some new heads from Lloyd and have a question about compression math. Currently my Golen 383 has 11.5:1. That's with 54cc combustion chambers, -16cc pistons, zero decked block, 0.040" gaskets. Lloyd says if I get the 21* Trick Flows with 54cc combustion chambers and everything else the same, my compression will be 10.97:1. Am I missing something here?
Old Nov 10, 2017 | 06:33 AM
bowtienut's Avatar
Lloyd's calculation is correct.
From the information you've given, your current CR is 10.97:1
Old Nov 10, 2017 | 07:27 AM
AdsoYo's Avatar
Good to know! Thanks!
