New Clutch Advise
Old Nov 10, 2017 | 06:47 PM
350 groundpounder's Avatar
Default New Clutch Advise
Any advice/experience for a new clutch install?
Im looking at the competition clutch stage 2.5 or 3.
Resurface the stock flywheel? Should i get a specific thrust bearing or anything else while everything is apart?
I put 9,800 miles on my top end rebuild this year. Making about 325rwhp. Best we could get was a 13.51 @ 107mph in 80 degree heat. Most 60 fts were 2.1-2.2 with the stock clutch and 342 gears. I also had M/T drag radials on. 1st gear felt so tall at launch, felt like i was losing half a second right off the bat. Hoping for low-low 13s at around 108-110 with new clutch and cooler weather. Also thinking of 390 gears instead of my 342's. Car is 99% street driven but sees the strip once in the spring and once in the fall.
Old Nov 10, 2017 | 07:35 PM
spudnick3119's Avatar
I put in a Competition Clutch stage 2 (I think it was a stage 2, maybe a 2.5) almost 2 years ago along with a RAM aluminum flywheel. It had horrible chatter until it broke in after about 500 miles, but I've been happy with it since.
Do the pilot bearing (I put in a bushing) and rear main seal while the transmission is out.
Old Nov 13, 2017 | 11:03 AM
Do you think that aluminum flywheel could of been causing some of the chatter? All i have read is great reviews on competition clutches.
Old Nov 13, 2017 | 11:18 AM
Gangly's Avatar
With that amount of power you shouldnt need anything special. McLeod, Spec Stage 2, etc.
Old Nov 13, 2017 | 11:23 AM
SS RRR's Avatar
Village Troll
GM thrust bearing if possible. You should always resurface the flywheel if you are installing a new clutch. Not doing so could lead to a limited surface area when the clutch clamps onto the flywheel which means it could start slipping and wearing prematurely. Same principle as when changing brake pads.
Old Nov 13, 2017 | 12:25 PM
Gangly, the competition clutch is nothing special its like $280 but has awesome ratings. Next motor build in a few yrs im looking for a 400rwhp 383.
Thanks SSRRR, prob resurface stock flywheel and i will look into the gm thrust bearing. This will be my first. Clutch install.
Old Nov 13, 2017 | 12:41 PM
smitty2919's Avatar
I went LUK and Fidanza aluminum FW(MUST be match balanced to stock PP and FW). The Autozone TOB I purchased last time lasted 6000mi...
See my thread:
https://ls1tech.com/forums/lt1-lt4-m...nt-clutch.html
Old Nov 13, 2017 | 09:14 PM
BALLSS's Avatar
I had the CC 2.5. for your HP it will be fine. 383 pushing 400 to the wheels, no.
Don't go with a lightweight FW if you street or drag race your car. Typically a FW can be resurfaced 2-3 times depending on how much they tale off each time. Stock Replacement FW's though are pretty cheap
Old Nov 14, 2017 | 07:21 PM
Most likely. I'm happy with the clutch, I just needed to get used to the aluminum flywheel being less forgiving in getting the car moving.
