Camshaft Research and Question
She doesn't need to accelerate like a bat out of hell, but she does need to give me some more SOTP feel than what I currently get. Again, I am seeking the fun of an L98 with instant low end torque on up through the mid-range. I am willing to spend the extra dollars to make it happen while keeping my stock rear axle ratio.
Stock clutch, m6 trans, 342 gears "10 bolt", UMI lca's, relo brackets panhard bar, bilstein shocks.
M/T 255 45 16 drag radials on salad shooters.
Crossing traps in 3rd gear at 6200rpm "real tach" at around 107mph.
I like the 342 gears on the street but its a turd of the line at the strip. Im thinking 390 motives, forged axles. I cant afford a 2k 12 bolt.
O.P. this is good info because you gotta think about gears when you build your motor up.
I figure its making "hotcam" horsepower #'s with the .533 lift and XE comp cams lobes that are more aggressive than the old hotcam lobes, i just have less duration.
Here's a gear/mph calculator for you to mess with:
https://www.andysautosport.com/learn...r/calculators/
You recommended the LPE 211/219 before. What are your thoughts on me having the stock cam in the engine advanced 4 or even 6 degrees in tandem with 1.6 or even 1.7 roller rockers with the geometry reworked for less strain on the valve-train? According to GrumpyVette's website, since I am not focused on high rev performance, I stand to benefit from higher ratio roller rockers and it will help boost my low end torque. Also, since I want more off-idle torque down low in the RPM band, advancing my stock cam would help shift my torque curve to almost match a B-body cam, which is what I am looking for. What do you think?
I am trying to go with a budget build and I figured perhaps advancing the cam and increasing the rocker ratio, even adjusting the lash, could give me what I want. The engine is going to need to be torn down and inspected anyways, I may need new piston rings which I was referred to Total Seal zero gap rings on ecomodder, plus I want a bump in compression, and to have ceramic coating on the piston heads and combustion chambers for better thermal efficiency, and to have the engine parts coated in MicroBlue to help reduce internal friction for better performance and fuel economy. Pretty much using racing technology for a daily driver but they are already doing this stuff on the newer engines anyways to squeeze out more performance and fuel economy, so why not pay more to have the same on my LT1? All of this without porting the heads and the intake manifold I wish to use. I figure there is no need for it given my requirements and the intake manifold won't require it anyways, as far as I know.
The torque I am expecting is what I get stock at 2000 RPM, but I want to bring it down to 1000-1500 RPM, which is why I was looking at advancing my stock camshaft and having 1.7 roller rockers put on the heads. Then I realized, why the hell not have a custom cam that uses the same lobe separation as my stock cam yet has a significantly higher lift to bring in that additional air to help the engine make more power down low and bump up my torque. Perhaps the cam can be ground to work with 1.7 roller rockers, although I need to remember my stock heads will only flow so much air and I don't know if this set-up would supersede this at a certain RPM.
I like how my car drives with it's stock camshaft and this is why I am thinking that I should not stray too far from the stock set-up, only to focus on how much lift can be given to a custom cam at 117 or even 118 lobe separation. I am not asking for massive amounts of torque to get my car moving like a bat out of hell, this is supposed to be a street car and driven conservatively most of the time so why do I need such a camshaft if I won't ever use that power production on the street. I also don't have the urge to show off and race others, so again, why am I getting a "sleeper cam" when I really want a revamped cam to the specs of my stock cam, having great vacuum production, a smooth idle, and a broad torque curve to work with the intake manifold I will be using which will give my torque curve a peak and which has been known to work well with my stock cam, so why not keep the specs the same except increase the lift? Also, I shouldn't have to worry about fuel economy since my low RPM power production will only be slightly more than what it was when stock with the caveat that I can now keep the car between 1000 RPM and 2000 RPM for city cruising and highway driving without instances where I might end up lugging the engine.
This is my logic for the matter...
Sounds like you want a "RV" cam. They make great low end TQ....because their purpose is for towing, not high RPM power.
The Crane 227 was what many heavier B-body ran with stock heads
or contact Lloyd to discuss a high TQ low rpm cam...if its other than what he refers his "sleeper cam" to
advancing your stock cam would not yield much
4:10's would be ideal in terms of ratio with the M6 but yeah are a little "fragile" in a 7.5". You would have to be sensitive to higher RPM clutch dumps with a tire but otherwise they would be fine though. Certainly normal driving would not be a stress on them.
You very likely would need a better balanced DS with the 3:90 or 4:10's though
Yes, I want more torque off idle, but my notion of "more torque" and other members' notions of MORE TORQUE are worlds apart! I am talking about shifting my torque level at 2000 RPM down to 1500 or preferably 1000 RPM, a laughably mild increase from stock but if it is any indication, I am looking more and more at a stock kind of cam with very wide lobe separation and as much lift as can be given with, perhaps, 1.7 rocker rollers. I will need to talk to Lloyd, or even the engine builder in my area can grind cams and he does both street cars and dedicated race cars along with his own dynotunes and emissions compliant tunes.
While I was interested in the Crane 227 and LPE 211/219, I forget, I am not using the stock LT1 intake and the effects of these cams with the other intake manifold may yield undesired results. This is why I am inclined to stick with what I have learned works well with this stock intake manifold and spread out the torque curve with the cam I choose.
