Radiator Choices
Old Nov 21, 2017 | 01:35 PM
Shownomercy's Avatar
Man-Crush Warning
Default Radiator Choices
My OEM radiator is finally on its way out, neck is leaking and end caps are leaking.
Before I buy a OEM replacement, are there any other options that offer full aluminum construction, drop in fit, and not cost $600?
Old Nov 21, 2017 | 01:40 PM
qweedqwag's Avatar
I've looked and looked, you can either get a OEM style for 100-130 bucks or, get an all aluminum for 450-500 guess its all depands on what you gonna do with your car, or how often you gonna drive it,
Old Nov 21, 2017 | 02:09 PM
SS RRR's Avatar
Village Troll
You don't ask for much. You only drive that turd when the planets align. Just get a GM factory rad. and be done with it. Do not buy from auto parts store.
You're welcome
Old Nov 21, 2017 | 03:31 PM
Man-Crush Warning
I just want a OEM level performance, but with metal end tanks.
You're welcome
Drove it 100 miles yesterday to the track, didn't race though.
And yea, prob grab a delco rad, just hate the plastic.
Old Nov 22, 2017 | 02:16 PM
Dirty_Bird's Avatar
Have a champion radiator if you wanna look at it. To make work you have to modify the rubber isolators and shroud a bit
Old Nov 22, 2017 | 04:40 PM
Man-Crush Warning
Got any more details?
Old Nov 22, 2017 | 05:13 PM
Dirty_Bird's Avatar
Going to pepboys in a bit, i can bring it with me if youd like
Old Nov 22, 2017 | 07:09 PM
BOLO's Avatar
When I swapped in the new motor, I ordered a new GM oem radiator from my local GM dealership. It's more than enough cooling for the new combo.
Old Nov 27, 2017 | 02:25 PM
BizZzatch350's Avatar
Moderator
I used a Napa replacement on my LT1 car, I had a nice Griffith I wanted to use, but the fans would hit my EWP. I like the stock fans and the car seems to run cool. One option, if you want to get spendy is, I started using Dewitts. Used one on my old C6 after the blower and have one in the GTA. They have 4th gen replacements as well as slimmer after market fans. Some thing to consider if you're dead set on wanting one with metal ends.
Old Nov 28, 2017 | 06:03 AM
smitty2919's Avatar
Look into Holley radiators.
