RMS Install Tool
Old Nov 27, 2017 | 05:53 PM
Snorkelface's Avatar
Question RMS Install Tool
Since I'm pulling the motor, even though it's pretty new, it's leaking out of the front and the rear, so I figure I might as well reseal the whole thing while I've got it on the stand. I know the rear main seal can be tempermental, so I want to install it right the first time. However, I saw these simple tools were crazy expensive. I found this setup from a company:
Anyone have experience with this? At $95 including the Fel-pro seal, it's a way better deal. The metal ring is just an optional sleeve it comes with in case you have grooves on your crank, which I shouldn't.
Old Nov 27, 2017 | 08:44 PM
Dirty_Bird's Avatar
The newer felpro teflon rms comes with a plastic ring to get it onto the crank. I then tap it on with a thick punch while going in a star pattern
Old Nov 27, 2017 | 09:31 PM
BALLSS's Avatar
you can use the sleeve that comes with the Teflon seal
I always use the rubber one....but I have the "tool". Bought it on ebay about 17 years ago for $40 used
otherwise...
The Teflon one you use the plastic sleeve and use a wide punch and or small hammer to tap it in, no oil on install
The rubber one you oil and just use a wide punch like previous post said to drive it in
Last time I saw one of the KM tools on ebay it was exploding wallet but if you find one cheap well worth it. Very plug & play for RMS install
Attached Thumbnails RMS Install Tool-km-rms-install-tool.jpg   RMS Install Tool-km-rms-install-tool-2.jpg
Old Nov 28, 2017 | 10:36 AM
SS RRR's Avatar
Village Troll
Use a rubber seal. Very easy to install with the included sleeve.
Old Nov 28, 2017 | 09:26 PM
Question
Holy crap, even used those are crazy expensive. I found a couple variations of that tool. It looks like maybe they're older version of the same tool?
One it the J-35621-1A
The other is J-35621-UPD2 which means update #2. I can't find a picture though. I could grab either of these for less then $70 which is half of a used ebay version of the -B model. Anyone know about these?
otherwise...
Old Nov 28, 2017 | 10:06 PM
BALLSS's Avatar
the 35621A is for the 90degree v8
the 35621B is for regular SBC incl. LT1
Old Nov 28, 2017 | 11:03 PM
Oh geez, got it, thank you. I cannot believe what they try and charge for such a simple, cast tool.
Old Nov 29, 2017 | 10:09 AM
SS RRR's Avatar
Village Troll
Don't make this more difficult than it needs to be. The RMS is about the easiest seal to replace.
Old Nov 29, 2017 | 11:42 AM
Sorry, I just hear a lot of stories about it not being installed right. I'm sick of having an expensive, built motor that leaves oil everywhere it sits. Since I'm pulling it, I just want to make sure this gets done right.
Old Nov 29, 2017 | 02:06 PM
BALLSS's Avatar
Just get the rubber FelPro RMS assuming your leak is from RMS.
You can see in the pic below there are 3 slots to use a screw driver to pry the old one out. Then just oil up the new RMS and slide it over crank and tap gently around the seal until it is flush with the RMS adapter. Very straight forward
Yeah the tool is very plug & play to install but this is one seal that itself is really easy to install without the Kent Moore, or clone, tool
