cc503 and 58mm BBK Idle Issue
Its hard telling because of how infrequently I drive the car. I can tell you, it didn't do it after my tune and I installed my cc503 in Denver. The only thing that changed since then was my tuner altered for the elevation change after I moved to Indianapolis. I have some winter projects going on with the car as of right now so its on stands in my garage and being tore down. The times it has done it to me I never had the opportunity to even check if the car was running closed loop, IAC Count or anything else. Hopefully this spring ill be able to do some proper diagnosis on the vehicle if the problem persists. But I'm out of state for Christmas vacation right now. I can tell you that under normal driving conditions 9 times of of 10 it wont do it. Usually happens after a hard accelerations and then a couple of down shifts during deceleration and then into neutral when it hangs up. Once the car comes to a stop it drops to normal. The reason I'm getting around to posting this now, is I thought I remember reading someplace that other LT1's with the same cam and certain aftermarket tb's had similar issues.
There was a accelerator pedal return spring on the firewall which was squeeking and probably the culprit, I also got the plunger where the throttle cable goes through the firewall. Then I lubed up any point I could get to where the cable travels through the engine bay and the throttle body itself.
You might want to take off your throttle body to clean and lubricate it, along with the cable. It might be something as simple as that.
That was my plan as soon as Im home, just don't have access to my car or equipment at the moment. Merry Christmas everyone
