1994 Firebird Foemula 5.7 Won't start.
I checked the air ram system to make sure everything was hooked up properly. I also sprayed a little starting fluid into the air hose and when i turned the car over i heard a backfire and seen flames. I dont like using starter fluid..... The car didnt start at all. I'm not sure what is going on. Please help me.
Thank you
if car has not started since you re-filled the coolant...when it does you need to bleed air from the cooling system.
basic checks for no start are to check fuel pressure and spark. You need a gauge to check fuel pressure.
if ignition likely ICM or opti. If you got water in opti while changing coolant it can be cleaned out but you carefully need to disassemble it which means removing it from motor. Not a small job
When I flushed the radiator i unhooked all the coolant hoses. There was a hose i unhooked that i did not realize opti was located underneath it. I did go outside with a heat gun and tried to dry the opti as best as i could. I noticed when i start the car after drying it i dont hear anymore back firing. The car didnt start up but everytime i turn the key it sounds like it wants to start. I think the starter is going bad or may have gotten wet. I hear a grinding noise from the starter sometimes.
Thank you for the help. Next time i know what not to do lol
You can try cleaning it but the Opti swap is a tedious job so replacing the Opti may prove to be the shorter path
The LT1 is unlike earlier Gen SBC with distributor placement not being the only difference. Cooling system needs to be bleed once it is open due to WP or hose swap because it is a reverse cooling flow system.
This site has invaluable 411. I encourage you to read about WP & Opti swap
Courtesy of shbox.com
http://shbox.com/1/4th_gen_tech1.html
