Tuning Question
Old Jan 3, 2018 | 06:04 PM
ak422's Avatar
Default Tuning Question
So the car has been sitting over a year now and I just put in a new starter, fuel pump with the racetronix kit. Here is my concern, I also added 30lb ford svo red top injectors to replace the stock 24lb injectors and added an adjustable FPR. Would it be easier to get it tuned with the stock FPR or leave the adjustable one on there and let them tune it out like that?
Old Jan 4, 2018 | 02:29 AM
KW Baraka's Avatar
Adjustable regulators on a NA engine add nothing.
If you're gonna keep the car NA.....then put the OEM FP regulator on permanently.
And definitely use it for the tune.
KW
Old Jan 4, 2018 | 07:50 AM
moehorsepower's Avatar
Using the FP regulator for tuning only comes into play if necessary, which I have only encountered a couple of times, this was with either forced induction where the injector wasnt quite large enough or on a huge solid roller set up. you can use the adjustable one, just set it to factory specs and leave it, if someone has to play with the FP on a mild setup, then they dont know what they are doing..KW is right, they dont add anything, well in a way, our cars came rich from the factory and back in the day, we would add an adjustable FP regulator and actually turn down the pressure and gain a couple of horses.
Old Jan 17, 2018 | 03:26 PM
ak422's Avatar
Ok thanks
also I am in the Florida broward area and looking for someone really good that knows how to tune these cars the right way. Does anyone know any shops around my area?
Old Jan 22, 2018 | 09:01 AM
quik95lt1's Avatar
Originally Posted by ak422
Ok thanks
want to drive to RI lol?
Old Jan 22, 2018 | 07:33 PM
blown94's Avatar
Default Lt1 tune
Nobody really tunes lt1 anymore, especially on a dyno. Best bet is pcm4 less, or ed Wright mail order. I'm doing the ls pcm swap for this very reason. Finding someone to tune a blown lt1 is the needle in a hay stack
I'm in broward as well, and could probably find somebody for you, but what you listed doesn't qualify for in my mind to waste $ dyno tuning. Do you have heads and cam mods? Long tubes?
Old Jan 23, 2018 | 10:54 AM
ak422's Avatar
4L60-E Transmission Automatic 30 lb svo red top ford injectors Long tube headers 3.5 inch exhaust Big cam New plugs/wires Cat delete, 58 mm throttle. Would I be better off switching to a ls pcm??
Old Jan 24, 2018 | 10:20 AM
BALLSS's Avatar
OP
don't drive around without a tune if you put in the 30 lb injectors. You will be over fueling the motor and wash down the cyl walls. Put the 24's back in until you get it tuned
Old Jan 24, 2018 | 12:32 PM
SS RRR's Avatar
Village Troll
^^^ and keep your foot out of it until it's tuned.
Old Jan 24, 2018 | 06:09 PM
CFLFORMULA93's Avatar
Ok thanks
check out fasterproms. They are over in tampa /st pete . Not sure if he messes with lts anymore but he used to
Old Jan 30, 2018 | 09:41 PM
ak422's Avatar
Still no luck. Does anyone know anyone else down in the broward area??
