Lowering nox/exaust smell from cam overlap
I really am thinking that injector timing adjustment is what I really need. If i give the motor the mixture it wants to run the best the exhaust smells strongly of raw fuel, but if i lean it out to get rid of the fuel smell the exhaust still stinks, just differently.
There appears to be no happy medium.
If i could delay the injector firing I could prevent some of the raw fuel dumping out the exhaust during overlap, and not have the fumes from being overly lean
so..
There's a parameter that I can adjust called "injector offset adder", it's description says "For low injector pulses, an offset in microseconds can be applied to further fine tune fueling."
I was thinking that this might be what I need to adjust, but I was really unsure about what to do with the numbers and if it was even the correct parameter. What I really need is access to the EOIT that ChopperDoc was referencing, but I could find nothing like it in my parameters list in tunerpro. I figured it just didn't exist or hadn't been found yet for the OBD1 pcm.
I'm browsing through the gearheadEfi forum this morning, and low and behold, there's a discussion about cam overlap and EOIT in the lt1 OBD1 pcm. Apparently there is an "End of injection target location vs coolant temp" parameter. I just had to load a different definition file to access it.
so I am going to crunch some numbers and do some experimentation with the setting. If i get anywhere with it, I'll update this with the relevant information.
it's crazy that there is still active work on the tuning options in the obd1 pcm.
so..
so..
so..
If there is a place around that'll actually smog test the car, I'd advise you to do it. Smog tests are actually a great tool to assess the overall running condition of the car. The results will help point you in the direction of what's wrong and where.
I know it's present in LS1 setups as Banish refers to it in order to try and get bigger duration cams to run better.
I think what you are referring to is "End of Injector Timing". I could be wrong, but I don't think that adjustment is not present in JetDST. That's why I asked for the table.
I think what you are referring to is "End of Injector Timing". I could be wrong, but I don't think that adjustment is present in JetDST. That's why I asked for the table.
