Build suggestions
so I have a new cc503 cam sitting around but I've been debating on whether or not to put that cam in or do go the more sleeper route with either crane 227 or lpe 211/219 or possible a sleeper cam from Lloyd.
Now if I go with a sleeper cam will I see much of a hp gain over my stock setup with 1.7 rockers?
Also I'm running Howard's 98215 sprints with my 1.7 rockers which don't have many miles on them will they be able to handle any of the cams I mentioned above?
if you have any experiences the cams I mentioned let me know if you liked them or not.
And its an A4 car.
The crane and Comp cams will work with 1.7 and the Howard springs
I assume you did pull the damper spring from the Howards..
I suspect the Crane 227 would give a little more low end TQ over the 503
Lloyd Elliott makes a sleeper cam "similar" to the 227
