Harmonic Balancer/Dampner Question for 383 Stroker
Old Feb 27, 2018 | 10:01 AM
Joe Soucy's Avatar
Default Harmonic Balancer/Dampner Question for 383 Stroker
My lt1 was stroked out to a 383 and when the crank was put in my engine shop internally balanced the crankshaft. I got my stock harmonic balancer/dampner still and was wondering what id need to buy for everything to be balanced out correctly.
thanks
Old Feb 27, 2018 | 10:20 AM
SS RRR's Avatar
Village Troll
The damper is just that, damper which "dampens" harmonic vibrations. There is no heavy side. The stock LT1 from the factory was internally balanced in the front and externally in the back. If your rotating assembly is all internally balanced then you can use your stock damper and then you will have to have a flywheel/flexplate zero or neutral balanced.
Old Feb 27, 2018 | 10:22 AM
Joe Soucy's Avatar
so if i were to buy a harmonic balancer, what should i look for or get
Old Feb 27, 2018 | 10:27 AM
SS RRR's Avatar
Village Troll
I am assuming you won't be turning the engine over 7000 RPM? If not, use the stock one if it's still in good condition. And it's a damper. Not a balancer.
Old Feb 27, 2018 | 10:28 AM
Joe Soucy's Avatar
Thumbs up
I am assuming you won't be turning the engine over 7000 RPM? If not, get a stock one, and it's a damper. Not a balancer.
okay cool and yeah im not to familiar with what it was called but thanks for letting me know
