97 z28 bogging need help!!!
Old Feb 27, 2018 | 09:13 PM
Knightrider11900's Avatar
Default 97 z28 bogging need help!!!
New to the site not a mechanic so bare with me in correct wording...bought a 97 z28 from somebodyhas a lt1 motor in it first problem I dealt with was a no spark changed the opti fixed the issue but now takes a couple cranks to turn over and run at idle...when running on idle seeing no issue when u set on pedal to hit the gas bogs down even if taking a ride around 1500 2000 rpms constant sputter bog feels like maybe a fuel air problems but I don’t no list of stuff done new opti new plugs wires coil map sensor tps sensor maf sensor crank position vehicle speed sensor o2 sensor battery scanned for codes no codes the guy I bought it from said he put a new fuel filter and said he deleted the egr I ran a live data on car maybe this could help...just looking for right direction some say vacuum lines some say Possible clogged injectors thoughts?
Attached Thumbnails 97 z28 bogging need help!!!-8c591ea0-056a-463e-91d3-ce1daf640000.png   97 z28 bogging need help!!!-1b9641cb-9664-4f5a-9cd9-d4db014fbe0f.png   97 z28 bogging need help!!!-3540215f-af68-4ca2-9222-715ffcb73450.png
Old Feb 28, 2018 | 12:10 PM
SS RRR's Avatar
Village Troll
Any backfiring? You need to check fuel pressure. Plenty of threads in here where you can research the steps.
