No start
The car is a 1995 pontiac firebird trans am lt1 6 speed
i removed all spark plugs installed new plugs the old spark plugs were dry but covered in black soot????
removed and replaced the optispark dist.
tested the coil resistance and it shoes 8.14k ohms from pin a/b/c/d to the ignition coil wire stem
i figured that it sounded like it was not getting fuel because it would spit and sputter while cranking over like it is starving
tested fuel pressure and received a reading of 42 psi at the port
i hooked my battery charger up and charged the battery to a full charge and still cannot get the car to start
removed and replaced the ignition coil module
i also hooked an inline spark plug tested up and turned engine over and it is producing a bright pink spark through the tester
when i installed the optispark i did not force the opti back onto the front of the engine and tried to line up the pin in the opti.
any ideas of where to look next or what to take a look at???? can anyone point me in the right direction or give me any suggestions???? this is my first lt1 engine so i am kind of at a loss as i have only seen one other and when i tested the opti was bad on it and the customer didnt want to replace.
also i havent been able to start it on starting fluid or anything because i dont have anyone that can hit the key for me, if i can i may go get a set of noid lights to see if the injectors are getting fire, also i will post an update on the car once i see there is fire actually making it to the cylinder
I believe the only year the data port can be jumped for codes is the '93. If you have an OBDI car you need an OBDI scan tool.
