Coolant leak with Procharger Bracket
I believe the two most bottom water pump bolts are the only ones which tap into water jackets. If you didn't put thread sealant on them then they will leak. I'd take the bottom bolts off, use sealant and then run through a torque sequence on all bolts to whatever torque value is recommended. You will have to drain the block or you will get a mess of coolant when you take the bottom bolts out (if that's what bolt holds the bracket).
It is the bottom bolt on the water pump that I removed. Guess I’ll dry the coolant and see what I can find out.
