UGH! SO close!!
Clean your car out, remove any unnecessary crap, like the spare tire, etc.
Air up the front tires to 45lbs. Record the air in the rear tires. After a launch, does it spin? If not add a few lbs of air. You want the most amount of pressure in the tire that still gives you a good launch. Most guys take them way down, too low, and after the 60-foot mark they're driving with practically flat tires. Ever try pushing a car with low air in 2 of its tires? It help you hook up running low pressure, but also robs power the rest of the way down the track.
Foot brake it, and record the exact rpm you launch at, and write it onto each timeslip. After 5 or so runs you'll find out what your car likes best. Some cars 60-foot best coming off of an idle, while others respond better at 2000 or so. No way to know until you try it.
Bring a bag of ice with you and a towel. Lay the towel on top of the intake and set the bag of ice on top of that. The towel will soak up all of the water. It will give you a much cooler intake charge and will eliminate heat soak between runs.
I will sometimes shift on my own or let the car do it on its own. the limiter is set to 6100 and it hits the limiter on the nose during shifts [right when its about to hit the limiter, if not one pop, it shifts.] I already have some weight reduction started. no sub box [while racing], back seat, passenger air bag.
Trap speed is unknown since the test n tune event didn't have the 1/4 mile mph... only et
