Gen 2 LT1 350 to 383
Hello, I recenrly purchased a trans am and am looking for a strong engine setup. Is a gen 2 LT1 out of a police caprice a good option? I was thinking to have it machined to 383 with a SC. Anyone have experience with this and an opinion if this is a good option?
yes a 383 LT1 can be built, just like any other GM 350 c I SBC
The Caprice LT1 would have iron heads which stock flow better than "stock" LT1 aluminum heads...but ported aluminum heads will perform better and save at least 50 lbs of weight
Basically all I'm saying is find out how much power you plan to make because a 4-bolt will be more stable than a 2-bolt at high hp/torque levels.
I'm not trashing a 2-bolt block by any means either. Just giving you a bit more info.
