Project The Beast
383 F1A Procharger 3.70 Pulley
Callies Dragonslayer and Callies Rods
Diamond Pistons
AFR 227 With additional porting. Flow about 350 at .600
237/251 .632/.614 114lsa
Johnson Axle Oiling Lifters
Injector Dynamics ID1000
Single Plane
Sumped Tank with Magnafuel 4304
Holley Dominator
Racewire Solutions Control Panel
Aftermarket Steering Column
Full Suspension
Viking Double Adjustable
Dana S60
FTI TH400
Strange Drag Brakes Front & Rear
Manual Steering Rack
Cutted Race Car no Factory Wiring
VP Racing C16
No vid yet but will post one up once I get a tune in the Holley. I’m want to hit 800-900. We shall see if I make it. That is a very similar cam and I would expect it to sound similar. It took me quite a bit of time to get mine back together after making several changes along the way. Decided to just gut it and make it a drag car. Strange Drag Brakes in the front and rear. Corbeau Seats. All factory wiring is gone. Running all Autometer Gauges. Still have some work to do on wiring management in the engine bay too.
https://1drv.ms/v/s!AsVVqVUy2mPekXz7e29Htc2N_d4X
https://1drv.ms/v/s!AsVVqVUy2mPekXvnLydfntu2gqu2
Sounds sweet Scott. Ramps up quick too. Still have yet to start mine but that's given me motivation in the coming days weeks to get it running.
I hope it will be doable. Time will tell for sure. I run a single plane intake and that is just he hat on it. I'll put more videos up once i have more too.
Sorry Scott not meant to hijack your thread
I was was thinking of ditching the y-pipe and just running mufflers straight off the headers and a turn down. Problem is I do have a wideband but dont really need it since I have two O2’s for my ecu and have 3 point SFC limits available space under the car.
Thanks! I'll definitely post those up once i have them. Hopefully both numbers will turn out pretty good.
