LT4 Edlebrock intake HELP
Hello everyone,
I have an lt4 Edelbrock air-gap intake. I need to install the EGR block off plates. I have the studs that went in the original LT1 intake manifold that I had used with the EGR block off plates previously. None of these original studs work with the lt4 Edelbrock air-gap intake. When I read the description in the summit catalog it says existing components of OEM intake should fit LT for Edelbrock air-gap intake. Has anyone experienced this problem? If you have any input please let me know I have been searching for the correct bolts over the past two days and cannot find anything that fits the lt4 Edelbrock air gap threads to hold the EGR block off plates on.
I've already installed the intake...and used 777 gaskets...
ironic edelbrock could not advise WTF they did....somewhere in their files they would have the machine specs they used to make the manifold. This is not something a retailer would necessarily know as they directed you to
I know it's a real pain in the butt. I'll probably tap the intake this weekend though. I don't really want to spend the time doing it, but It looks like it's the best option in this circumstance. I'll just have to spend the time making sure it's done well.
May be better to pick up a few sizes (SAE & Metric) studs to see WTF size hole/thread it is if the holes go into intake
Thank you. I don't believe any of the holes are blind....I don't think any of those holes go into the intake manifold.
Back in 98 our local Impala SS club went to Edelbrock for a tour. Vic and his staff were great hosts. The LTx air gap was just coming out then which they showed. Sadly it proved to be no real performance improvement over the stock intake....or LT4 one
Thanks
