Dtc 36
I hooked up my ALDL cable to my laptop running scan9495. I got DTC 36 and 41. 41 went away, but 36 stayed even after clearing the code. I just replaced the opti a couple thousand miles ago along with the water pump, wires, plugs, etc.
I went to shbox's website and looked at his troubleshooting guide.
These are the results of my wiring harness tests:
ICM Harness pinouts-
A= 11.93
B= 0.08-1.3
C= 0.017
D= .11.92
Optispark Harness pinouts-
A= 5.02
B= 4.97
C= 11.93
D= 0.0
All of these results look OK, with the exception of ICM pin B being on the low end.
Any suggestions on what the problem might be? Unfortunately, it's looking like it is the Optispark again, but if there's anything else I can try first, I'd rather do that, because doing an Optispark swap is a giant pain in the butt, and I don't want to just throw parts at the problem.
Thanks in advance for any ideas.
I know this gets asked a lot, but since new old stock AC Delco or Delphi units are pretty much impossible to find, are there any other aftermarket ones that have a decent track record now? Did anyone figure out any other cars that might have the desired Mitsubishi optical sensor that I could transplant into a new opti?
