Got motor put together tonight. Have BIG problem
Old May 7, 2018 | 10:57 PM
Roadrunner96's Avatar
Default Got motor put together tonight. Have BIG problem
So tonight i finally got my motor back together. When i was filling the cooling system, water started to come out the back of the passenger side head. When i installed the crossover line i know the bolt threaded in properly when i started it. But it must have a bad thread in the head that caused the bolt to not want to install straight. So i was wondering if i can not easily fix this if i could put a plug in the back of the heads and make a crossover line for the front of the motor? This would save me from having to remove the heads.
Old May 8, 2018 | 07:41 AM
Muncie4sp's Avatar
You don't want to plug it - the rear of the block needs to vent. Get the old bolt out and examine the threads. shbox has the part numbers for the bolts and gaskets. http://shbox.com/1/Parts.htm search steam on his site to find it.
Old May 8, 2018 | 09:37 AM
i orderedd some AN fittings last night. Going to get away from the metal steem line.
Old May 10, 2018 | 10:04 AM
Z28Roxy's Avatar
Yeah you want to do something like this:
https://ls1tech.com/forums/lt1-lt4-m...-pictures.html
I did something similar, my solution isn't as pretty though, I just used rubber hose over the an fittings.
Old May 10, 2018 | 11:27 AM
soloman369's Avatar
Did you make sure to put the Hex key bolt on the side on the rear passenger head. Normally it has a bolt already but some times ppl take them out. Its where the coolant temp sensor goes.
Old May 11, 2018 | 03:49 AM
i just received my parts to do that same setup. Im going to work on doing that this weekend.
Old May 11, 2018 | 03:50 AM
i never took it out. I do know that it is coming from the steam pipe bolts to the head.
