How to "lean out" A/F - only on cold startup
Old Jun 12, 2018 | 08:24 AM
wrd1972's Avatar
Default How to "lean out" A/F - only on cold startup
Car has a dyno tune, and when I start the engine up (cold start only), it seems to be overly rich and runs very rough for a minute or two. Then, it smooths out nicely.
So my question. How can I slightly lean out only, the cold start-up A/F conditions?
Thanks
Old Jun 12, 2018 | 09:55 AM
SS RRR's Avatar
Village Troll
Sounds like the tables in open loop are shitty. Pretty sure you'll have to get that part looked at through tuning software.
Old Jun 12, 2018 | 01:29 PM
wrd1972's Avatar
I can tweak the tune. No problem there.
Might there be a safe way to go reduce fuel in certain "areas" that only affect OL idle? Maybe certain cells?
Old Jun 12, 2018 | 04:03 PM
moehorsepower's Avatar
What software are you using? you do want it a little rich on startup like a choke on a carb, but not so rich as you described.
Old Jun 16, 2018 | 07:40 AM
wrd1972's Avatar
Ive got Tunercat. Its been years since I did any tweaking on it but I think I can recall the basic process.
Old Jun 19, 2018 | 12:23 PM
Ed Wright's Avatar
9-Second Club
Look at the MAP values at idle with your scan tool. That is the mail part of the Open Loop Air/Fuel table you want to lower the numbers, and at the RPM you are seeing. Should be part of a dyno tune. Should be seeing no black smoke.
