Slightly Rough Idol after Fuel Pump Replacement
I have had it hooked up to the shop's scan tool computer, but they say it doesn't register any misfires, and there's no other clues as to what might be happening. There's no misfires that I can tell at other engine speeds above idol, it still runs very solid. My first thought was fuel injectors, but I'm not really sure how to troubleshoot them. I ran a couple cans of SeaFoam through it to see if I could even notice a difference, but no change that I could tell.
Short of pulling all of the injectors and having them tested or replaced, any thoughts on something else I can try? I should point out, it happens whether the engine is cold or warm. Thanks for any/all help!
Put vac line back on and the pressure will drop around 7 psi (normal) then drive around where you can have a good "sustained" WOT pull in any gear. The fuel pressure should raise some...never drop
what could have happened when your pump was replaced is debris could have gotten in fuel line, past the fuel filter, and partially clogged one or more injectors. A 20+ year old car with 25k mi on it suggests it sits most of the time. Fuel system can develop crud that gums up stuff like injectors
injectors can be easily serviced. I use www.cruzinperformance.com
$15 per injector IIRC
Initial Pressure when pump is running when ignition is turn on = ~43psi
Pressure While ignition on after pump stops = ~41psi
Pressure After car has sat for about 10 minutes = ~40psi
Pressure while car started and idling (and running at normal speeds) = ~33psi
Pressure while rev'ing = ~37psi
I've read that these numbers are pretty low, so I suspect that's the cause of my rough idle. I was curious what the opinions are on the common cause, whether it would be regulator or pump. I also wondered if maybe the answer is the regulator, is that what could have caused my pump to die at such a young age. But that's just a theory. Any thoughts greatly appreciated!
Run engine, shut off, pull vacuum nipple off FPR...is there any sign of fuel or fuel oder in the rubber nipple? If so FPR is bad
The simplest way to similulate WOT is to remove the vacuum line from the fuel pressure regulator. The numbers you listed here do not mean anything unless these are values with that line removed.
I also had the Fuel Injectors professionally cleaned and tested. They were already in good shape also.
So I'm still left with the mystery of the slightly rough idol. I have no idea what to look at next. If it's not the fuel pump or the injectors, and my shop didn't find any vacuum leaks. It's not horribly rough, just is obvious to me that somethings not right. If you were standing behind it, you would think it was cammed more than it is. The shop's OBD2 computer says it doesn't show any misfires logged, but I plan to look a little deeper into that. Other than that though, any other idea what could lead to a rough idol on a very solidly running low mileage engine? Thanks.
