How does the PE system in OEM LT computers work/
They are usually 0 or small neg or positive numbers, so id assume its a modifier over something like the Open loop AFR vs Load vs Coolant Temp table in LT1Edit (unless its something we cant see?) Positive numbers make it richer though which I find off if its a simple adder
So Say at temp and load your in OL is 12.0, and have 5% in PE means itll target 5% richer? So 11.4?
https://www.camaroz28.com/forums/com...3/#post6540230
GM OEM ecu uses the logic, so thats applicable for lt1edit or tunercats, thank you
Brian, occasionally... I try to keep it to a minimum LOL
