97 SS Aeromotive AFPR 13301 question
Hey folks I have a 383 with a Vic E efi intake and I am running -8 feed to a Y to -8 to each fuel rail with an Aeromotive 13301 regulator on the front crossover line and I'm wondering where you guys are mounting the regulator?
Will it be ok mounted in the crossover line or does it need to be solidly mounted like to the head on the engine or the body of the car also I have a ZEX perimiter nitrous plate can I use one of the ports in the regulator to feed the nitrous?
Yes I am running a Edelbrock Victor E efi single plane intake and my feed line is coming up behind the engine to a Y and each side of the Y is feeding one fuel rail then at the front of the fuel rail is the crossover line and this is where the regulator is connected then the return comes out the bottom of the regulator and back to the tank.
