Very odd blown headgasket
1. What head gaskets would best be used for a stock motor. Fel pro 9966 pt or the fel pro 1074, from what iv read its hit or miss on the 9966. But the 1074 I haven't seen a post on any failures. Mind you i do run the motor hard from time to time.
2. Head bolts. The only head bolts I could find seem to be for the iron heads with no washers so that leaves me with the arp 134-3601 (I believe). I'm not opposed to goin arp, just don't want to go over board on something not needed. If stock bolts are fine and I can get a part number for ones with washers cool. If not no biggie, I'll go arp.
3. Head bolts torque. If I go arp then it should be the 3 step up torque method correct? If it's stock GM bolts it's 22ish then the angle method?
ARP's all the way especially since they can be reused.
If that part number is for SBC and does have the washers then get them. I believe there is a tapered side to the ID of the washer and that goes against the bolt head. Make sure to put a trace of oil between the bolt head and the washer before torquing.
I've always torqued in a 3-step fashion for head bolts. I don't know what the torque spec is on those head bolts. You may want to look up the part number or call ARP. I've always stuck between 65 and 70ft. lbs in three steps. Don't forget there's also a torque sequence you must follow or risk warping the head and being right back to square one.
