Vacuum 7 lbs/inch??
Old Jul 20, 2018 | 06:04 PM
Greg88's Avatar
Default Vacuum 7 lbs/inch??
hey guys,
i have a 355 cubic inch engine with AFR 190 heads and a 223/230 custom grind cam. I just added a Procharger D1SC on it with a 10 lb pulley. My gauge is showing 7 on the vacuum side at idle. Is this normal for my application? I have no idea what it was prior to me adding the Procharger because I never had a gauge on it! I also
added a catch can to it from might mouse and used his opinion on how to hook it up! Any help or guidance is greatly appreciated!
Old Jul 21, 2018 | 06:10 AM
Greg88's Avatar
Here is a run down of my engine specs:
Short Block
Bored .030 over = 355ci
Mahle Forged 5CC Dished Pistons
Eagle 6” H Beam Rods with ARP Bolts
Stock Crank cut and polished
Melling High Volume Oil Pump
Heads/Cam/Intake
Lloyd Elliot Custom Grind Cam
223/230 .565 Lift 112LSA
LS7 Lifters
Cloyes Timing Set
Comp Pushrods
AFR 190cc (Ported Flow 294/208 CFM)
60cc was 65cc – 2.05/1.60 @.600
Crane 99893 Double Valve Springs
ARP 7/16” Rocker Studs
ISKU Adjustable Guide Plates
Comp 1.6rr NSA 7/16”
Ported Intake
58mm Throttle Body
80LB Siemens Deka InjectorsAeromotive Adjustable fuel pressure regulatorATI Super damper Balancer and Hub
Pace Setter Long Tube Headers
Off-Road 3” y-pipe
OtherProcharger D1SC with 7.65” Crank Pulley and 4.00” blower pulleyAluminum 3” Piping with Ebay FMIC and Red Race Bypass Valve
AEM- 30-3300 Methanyl Kit with 1000mm nozzle
Racetronic 300lph fuel pump and upgraded wiring harness
Mcleod Racing Twin Street Clutch
10.3:1 Static Compression
Old Jul 21, 2018 | 02:16 PM
chadtn's Avatar
Sounds low to me. For comparison, I have a 302 Mustang with a larger cam than that and it pulls around 8-10lbs at idle. My brakes are ok after the car has been running for a minute, but it's only good for one panic stop before the booster runs dry. If I need to hit the brakes hard twice in a short period of time I will most likely be wrecking. heh...
Might want to look for vacuum leaks or double check the gauge. You could also have an issue with how the gauge is plumbed, or location of the vacuum source. Are you running a vacuum reserve canister, or having any issues with the power brakes?
Chad
Old Jul 21, 2018 | 02:25 PM
Greg88's Avatar
Chad
Not really having any issues that I can tell with the brakes yet. Well considering I have used both electronic and mechanical gauges and they are both reading 7.5 I am going to assume that not the issue. I am going to mess around with my mechanical gauge on different ports and see if its all the same. I guess the best question is am I compromising horsepower/torque with a low vacuum running engine?
Old Jul 21, 2018 | 02:29 PM
Greg88's Avatar
Here is a very poor picture of how I have my catch can hooked up with guidance from Mighty Mouse. I have the hose running from the pass. side valve cover to the intake of the can. The exit (PCV) side enters into a vacuum port beside the old PCV valve. The old PCV valve location has an orifice and a hose that now runs to the non pressurized side of my supercharger. I capped the port on the TB where the old hose went from the pass. side valve cover. Does this look/sound right?? The can obviously has a filter on the top not sure if this would cause a vacuum/boost leak though?
Old Jul 21, 2018 | 03:53 PM
chadtn's Avatar
I wouldn't really worry about low idle vacuum unless you are chasing down some other gremlins. ie...Trouble tuning a MAF car due to vacuum leaks, power accessories losing vacuum during normal driving/idle, or oil/blow by issues.
Not sure if I asked before, but is your vacuum source for the gauge directly off the manifold? Some times people tap/tee five things in some funny places and get strange readings. heh..
Lot's of application specific things that can affect your readings as well depending on if it's a MAF car, (blow or draw through), are you running a blow off or bypass system, are check valves in the proper places and proper orientation...
Chad
Old Jul 21, 2018 | 04:59 PM
Greg88's Avatar
Chad
I have it t'd into the drivers side intake manifold that runs to a solenoid. I also have my Bypass valve T'd into that as well. Im going to put my mechanical gauge directly on the intake outlet and see what it shows there.
I have the red race bypass valve if that is what you mean! is that what you mean with check valves or are you talking about the PCV system? As far as I know there is a check valve in the might mouse catch can.
Old Sep 6, 2018 | 02:06 PM
SRZ's Avatar
SRZ
Just to give you an idea. My old setup 388ci. 8.8:1cr, CC306 cam, F1, ebay intercooler etc...new motor I had 19" of vac. When I washed the rings out due to my lack of tuning skills I had 7-10" of vac. This was on a motor with less than 1K miles total and when it did finally die, I did a compression test and had less than single digits on 5 cylinders and the remaining had 0! That's how much air the F1 was pushing just at idle...enough to start an engine alone.
Not sure if you got it sorted out since you last post but as others have said you may need to find another way to tap for vac or check you cylinder pressures. just for giggles. I would think 15-20" would be the norm with a healthy engine but I'm no expert on the subject.
Old Sep 7, 2018 | 08:59 AM
SS RRR's Avatar
Village Troll
Yeah for a 112lsa cam that's extremely low. Weird how you haven't experienced any issue with brakes? Did they suck to begin with? I'm at 11" now and can definitely tell a difference between normal stopping and when the engine is decelerating while applying the brakes.
Old Sep 7, 2018 | 07:57 PM
ACE1252's Avatar
If I recall correctly, I've got around 15-16" of vacuum with the CC503 at idle.
Old Sep 9, 2018 | 10:04 AM
Shownomercy's Avatar
Man-Crush Warning
My heep makes 17-19in at idle pending temps, cam is very close to yours, but I am 383ci
I would double check that your BOV is functioning correctly.
Old Sep 10, 2018 | 09:16 PM
Greg88's Avatar
I’m running 11-12 now, not sure why it was only showing 7 prior. I never noticed much differed in the Brakes performance. Tuner said it’s bedause of my cam.
