A little help with oil pumps
If you have done as many of these as I, you know that book data may be correct, or not.
I have torn down more than one "large journal SBC (Including LTXs) with .001" rod bearing clearances. Don't spin that sucker 6K.
The standard minimum clearances used by many is .001" per inch diameter of the crank shaft journal. High oil pressure (and certainly not an HV pump) won't make up for a lack of bearing clearances. Too tight, but with high oil pressure will eventually bite you in the butt.
Mine goes 8400 to 8600 (depending on air) in the lights, has no problems with 45 psi.
And, having one without seeing any issues does not make it a smart move. Some don't seem to get that the original pump is bypassing excess oil back into the pan. They pump at LEAST as much oil is needed. A 60 psi Spring lets that little piston in the cap plate on the pump back up at 60 psi to allow EXCESS oil back into the pan. If the pump was not capable of pumping more oil than the engine needs, the pressure would not go up with a stronger Spring. Understand? Hot, thin oil, loose clearances will often show oil pressure dropping at idle. The bypass is closed then. When it is showing the Spring pressure, say 60 psi, it is pumping excess oil back into the pan. Any time pressure is that high, it is pumping all the oil the bearings can use, and the bypass is allowed to open by the spring, putting excess back into the pan. A high volume pump would simply be pissing more oil back in the pan than the standard pump. Higher oil pressure at a hot idle seems to make the less knowelegable feel better. GM says ten PSI per 1000 RPM is desired. That makes 8psi @ an 800 RPM idle good, right?
