Boost - NA - Trying to bring up compression.
I have a 383 lt1 motor currently built 8.1:1 compression I bought in a parts car. Wanting to use the shortblock and bring up the compression back to na. Currently has 65cc afr heads and was going to swap out to a set of ported stock casting around 54cc. How much of a difference would the head swap and a set of thin .026 gaskets net me for compression bump?
thanks.
thanks.
Assuming all things stay the same with pistons, and a .026 HG, going from 65cc to 54cc gets you almost a full point of compression. Without knowing what HG you have now, you can't get a true answer though.
Just throw a 88mm turbo on it and let her eat
