Rough idle, lights dimmed and almost died
Old Sep 3, 2018 | 02:46 PM
ebabyflex's Avatar
Default Rough idle, lights dimmed and almost died
Hi guys I have 94 z28 thats stock except for cold air intake and exhaust. For the last couple days my car had been idling real rough at a stop light but as soon as I hit the gas its completely fine. Also it has almost died on me at a stop light today, the lights dimmed and the battery level went super low, but again as soon as I hit the gas everything was fine. That's part 1 of the problem. Second part is that it heats up super quick when I'm not driving on the highway. When I'm on a side road the temp gauge will go up and down for a little bit then once I get going for a minute is cools back down to normal temp.
So to sum up on the highway its completely fine, at stop lights it idles real rough and it struggles to stay alive, it usually goes up in down from 700rpm- 300rpm (unless i put it into neutral then its okay). Then when not moving it heats up super quick until I get air flowing into it from driving. Today I noticed I have a slight coolant leak from a hose right about the opti spark; I've read other forums saying a coolant leak could of leaked into the otpi and mess it up. I'm thinking that is maybe the problem? And the running hot problem may be from the slight coolant leak. I did replace the opti spark in November of 2017 after the car kept dying randomly on me and replaced the ICM at the same time.
Any help would be great, thank you!
Old Sep 4, 2018 | 09:21 AM
Shownomercy's Avatar
Man-Crush Warning
Get the alternator checked and verify your battery is good
Old Sep 6, 2018 | 10:08 AM
SS RRR's Avatar
Village Troll
Get a volt meter and check the alternator while it's running. It should read at least a steady 14.5 to 14.7 volts. If it's fluctuating or less than that 14 volts then the alternator is no good. As far as the heating thing, where does the needle end up when you say it's hot? Do you hear the radiator fans?
Old Sep 7, 2018 | 10:14 AM
ebabyflex's Avatar
Good idea I’ll double check those
Old Sep 7, 2018 | 10:20 AM
ebabyflex's Avatar
I started it the other day to let it warm up and it got to the point of overheating in like 5 minutes in the garage. I am pretty low on coolant from the leak so I think that’s why it got so hot so quickly and no I didn’t hear the fans kick on but I did not have the a/c on. I’m replacing the coolant hose tonight and I’ll check the alternator as well. My dads a mechanic but he hasn’t had time to look at it until tonight so hopefully he can help!
Old Sep 7, 2018 | 12:10 PM
SS RRR's Avatar
Village Troll
Define overheating? Is the temp gauge pegged or close to it? Your fans should come on without the use of A/C (I believe) at 228* for primary and 235* for secondary. Don't quote me on that. Not 100% positive.
Old Sep 7, 2018 | 12:20 PM
ebabyflex's Avatar
Its right on the red line for overheating and the check gauges light came on. I just filled it up with coolant and I’m gonna start it up again and see if it gets that hot that fast again
Old Sep 7, 2018 | 12:25 PM
SS RRR's Avatar
Village Troll
There is a bleeding process you should follow before starting the engine, which involves the bleeder screws on the thermostat housing and heater hose.
http://shbox.com/1/4th_gen_tech2.html#radflush
Old Sep 7, 2018 | 12:39 PM
ebabyflex's Avatar
haha too late.. I started it let it run for about 5 minutes it barely got over the 160 degree mark. So that’s a a plus, and I read on the website you shared when the fans kick on but they didn’t kick on the other day when it overheated, why would that be?
Old Sep 7, 2018 | 02:02 PM
SS RRR's Avatar
Village Troll
No idea. Perhaps a short in the circuit. You should still let the coolant system pressurize and loosen the bleeder screws to ensure there's no air in the system.
