lt4 hot cam install troubleshooting
Here's the backround info: every sensor is new and Delco with proper voltage reference and reading properly via multi meter, snap on verus and Matco maximus scanner. No codes, no ses, no po300, no knock or misfires in the current or history counts, o2's are Delco and read/flux as they should, all new Delco injectors, opti, coil, icm, plugs(gapped as per hcc instructions and pcm tuner) wires, fp regulator, pump, and filter, Holds steady 15psi vac at idle and fp 45psi at the rail increasing with revs never going below 40psi, (opening relief valve does not stall the motor) no vac leaks, no exhaust leaks, short term and long term fuel trims +/- 1or 2, and 13.25v of batt when running.
Mods done:
1997 lt1 with Complete Lt4 hot cam kit, 1.6rr and springs, extreme duty timing, long tubes, no cats, slp cai, loudmouth, the egr, a.i.r., asr have been deleted, has a Soloman tune, all parts installed by professionals as per GM spec or as listed in the kits instructions...
What the heck am I missing??
also, you say you have 15psi vacuum at idle. is that supposed to be your MAP reading? I'm used to seeing map in kPa and a quick internet search says a LT4 Hotcam should be at 45-50kpa at idle (6.5-7.5 psi). I'll wait to hear if MAP is what you were talking about before going down that rabbit hole.
Thanks for all your suggestions so far y'all, i had a couple other minor issues that have been solved and I have ruled out pcm, opti, coil, icm, maf, and map sensors. I have now narrowed the issue down to a lean condition on bank 1, (the fuel trims show 20% positive enrichment, and are in the single digits on bank 2) so I marked and switched all injectors from one side to the other and problem remained the same on bank 1, I have practially soaked the intake in carb cleaner to try to find a leak but so far nothing, im going to try switching the o2's to see if it switches banks, if no change im thinking of checking/ replacing the header gasket on bank 1(although i hear no leak). After that I cant think of anything else that would only affect one bank, I have checked the valves and they are adjusted properly. Any more suggestions?
Car now starts, stays running, and is now driveable, the only issues left are hesitation till aboit 2500-3000rpm, and surging idle commanded is 800 and it will dip as low as 650 then surge to 950 then rest at 800-850 for about 5-10 sec then surge again, (I know its not the lope theres a noticable difference) problem is worse when hot, and running longer, then it needs spoon feeding at lights to keep from stalling. I have replaced, reset and adjusted the iac valve problem remains.
