Boosted LT1 runs hot
I would look into the cooling system as pointed out and perhaps check for warped heads causing leaks. Did the previous owner ever look into this running hot condition?
Thank You
Biggest things that help cooling IMO are the plastics that actually channel the air, a quality radiator and knowing your EWP is getting solid voltage, run it through a relay don't just direct wire it.
I built a head cam D1SC Camaro (made 630whp), left in all stock plastics, installed a Dewitts radiator, made a custom shroud with 2 12" fans for a slim install for more room for piping, Meziere pump and installed a 160*. Car still has 100% AC and the guy loves riding around in 4th at 3500rpms...he's never seen over 190* even on a 100* day...
