97 Camaro Z28, Is The TH24x Conversion Worth It?
Old Oct 9, 2018 | 03:09 PM
blk97z28's Avatar
Default 97 Camaro Z28, Is The TH24x Conversion Worth It?
Car - 1997 Z28
Miles - 75K
On my second opti and it is vented, no issues so far. Recently just did Nasty Z28 custom OTVC MSD 8.5 wires with Hi Temp Boots and Heat Sleeves last year PLUS install labor. Goals of the car is a complete UMI adjustable suspension (only missing a K-Member, Upper and Lower A-Arms).
Mods Wise Goals - LE custom cam, LE Ported heads stage 1 or stage 2 - Probably stage 2, 50-75 shot, shift kit, 3600 SS stall, built trans. Eventually have a nicely built 9in rear end.
Long Term Goal - Get a nice used 2002 Black Camaro SS M6 with low miles under 20k (prefer under 15k or less) and collect the two cars. The 97 being the 30th and the 02 being the 35th, wife and I want to cruise to car shows together and doing something my dad wished he did (kept his old muscle cars when he was a kid).
Opinion needed?
Car is currently schedule to go to a shop to get a tune at a shop and this is my issue I'm stuck with.
Tuning software for my car that I must provide the tuner is $400 plus like $300 for his time tuning some stuff out and editing, then there maybe an issue with the PCM that is in the car.
I'm really struggling with what exactly to do here. Should I bite the bullet and buy the JET DST for $400 then the time tuning for $300 plus any other issues or just put that money towards the Torque Head 24x conversion and then sell all my MSD OTVC wires and everything else,opti wise etc.
Old Oct 9, 2018 | 03:57 PM
KW Baraka's Avatar
Check the sig.
Old Oct 9, 2018 | 04:53 PM
blk97z28's Avatar
Originally Posted by KW Baraka
Check the sig.
How do you like it?
Old Oct 9, 2018 | 07:18 PM
blown97ss's Avatar
Love the way my car runs with the efi 24x system. Its real essy to find a shop to tune the car and it starts up and idles like a stock car.
Old Oct 12, 2018 | 10:14 AM
Camaro_freak's Avatar
There's a video in the thread below about a way to run a 411 PCM using the opti as the cam sensor and the stock 96-97 crank sensor. Requires some work but WAY cheaper than an 24X setup and you should be able to have it tuned anywhere.
https://ls1tech.com/forums/lt1-lt4-m...-computer.html
Old Oct 16, 2018 | 11:54 PM
KW Baraka's Avatar
Originally Posted by blk97z28
How do you like it?
Lovin' it!
Revs clean past 7K RPMs without a hitch. Never have to worry about bad optis or the rev-limiting of the LT1/4 PCM ever again!
Of course, I'm rolling on a solid0roller stroker…...so there's that.
KW
Old Oct 17, 2018 | 09:10 PM
blk97z28's Avatar
Lovin' it!
KW
Thanks guys! Just bought the WORKS kit through TH and my shop got a cut off the price.
Old Oct 18, 2018 | 10:29 AM
Toronto LT1's Avatar
How much did they slice off the price?
Old Oct 18, 2018 | 10:38 AM
blk97z28's Avatar
i was told they do a price cut for performance shops like $150-$200 off the kit I believe. For the works kit it was originally $1635 and I paid like $1400?
