Throttle response problem after k&n install
Any codes?
PS- If you are unfamiliar with any of the terminology, go here: www.shbox.com. The best reference site for the LT1.
A paper filter will run just as fast.
When I mentioned needing the MAF turned around, several said "I thought that was supposed to point to the air filter." Really??
pointing the direction of air flow never occurred to you? Some people should just leave their vehicles alone.
In my own setup the K&N read higher airflow values and kept the MAP from dropping off as much at high rpm. FWIW, this was datalogged on a Vortec 350 application that uses the same filter. Picked up 3-4 KPA and 10-12 gms/sec between 4,000 and 5,200 rpm shift points. Stock heads, stock cam, stock vortec intake manifold, stock exhaust manifolds and stock 3" dual exhaust to the muffler with the only change at that time being a dual 3" in, single 4" out muffler and a 4" tailpipe as well as the TB lip removed.
I hit the MAF sensors on even stock cars with paper filters with CRC Maf Cleaner every filter change. Just driving on the rain soaked oily nasty roads often contaminate the sensor resistors.
I have also had a cheap crappy aftermarket paper filter "STP" cough get rain soaked and self destruct blocking one of the MAF sensors in a car I was driving.
Op had his elbow FU, as noted as a possibility by SS RRR. Likely Ray Charles could have seen that but OP figured it out. In addition to the FU intake elbow causing a significant vac leak and unmetered air entering motor.....a "new" K&N filter out of the box is typically "moist" with fluid which as Ed Wright noted gets on the fine wires of the MAF corrupting their sensing thus giving PCM false air reading which skews fueling. Careful cleaning of the MAF wires is required if contaminated with oil
Over oiling the filter element will cause MAF problems so take steps to eliminate that possibility....
Using compressed air through the oiled filter element (from inside) helps purge the excess oil from filter before use. If cleaning and then re-oiling a K&N, oil VERY sparingly and let dry overnight before install IMHO if you are using a oiled filter
He
With that said if I could find a cone paper filter to replace the K&N, I would use that instead of a oiled filter
