Looking for a Stock Tune
About to get the old turd running again. Anyways my OBD2 ecu has a PCM for Less hotcam tune from when the car had a hotcam. But that is no longer as its going back to a stock engine. Anyways I had picked up an OBD1 ecu a while ago to try and do my own tuning. Since I have my brothers copy of tuners cats since he sold his car I can flash the OBD1 Ecu. The one I have has a B-body tune on it. Does anybody have stock F-body tune laying around? Car is a 6spd if that matters(I know I can adjust in the pcm but not sure if the auto vs manual tune were different). I have swapped my knock sensor to an obd1 unit and plan on swapping one of the Lt-4 knock modules I have laying around in.
Yeah did not think there was. Can always check the box for manual or auto...forget what it is as its been a while. Either way a stock 95 6spd tune will work just fine. Just looking for something I can use to start the car. The other OBD1 ecu has a 385 tune on it for the junkyard 385 and I am just not wanting to mess with it. So stock tune for now will at least run the car. I will have to turn all the emissions stuff off anyways as all of that is long gone. Tho I did find my working A.I.R pump today in the garage.
