Stalled and won't start
I have a 97 Trans Am
In August I replaced the fuel pump and ICM. I started the car Saturday for it's weekly start and fired right up. Then stalled now won't start again, just turns over. I hear the fuel pump kick on when I turn the key. The original Opti is in the car, but I only have 37,000 miles on it.
Could the Opti be gone?
Is there an easy way to tell?
Thanks for reading or any input.
If FP checks good move on to ignition
ICM/Coil/Opti are then likely candidates. If the ICM you replaced was not a AC Delco....might want to test that. Some auto part stores have a tester for it....but it can test good cold but fail when hot. The later not something that occurs during bench testing...unless you use a heat gun on it
So I can't get a fuel pressure gauge until the weekend now. I had replaced the ICM and fuel relay in August when I replaced the fuel pump. So I replaced those with the old ones that I had (because it wasn't them in August it was the fuel pump).
My buddy just came over with a spark plug tester and we put that on, I am not getting any spark.
Like I said the car was running fine, started no problem, just died at idle and now just turns over.
So now I am thinking coil????
I also checked that all 3 connectors have continuity between them.
Does any of this makes sense?
