Total Suspension Overhaul List + Custom Mounted Power Steering Cooler (Ton of Pics)
As the title states, I just overhauled a lot of my suspension and added a custom fabbed up power steering cooler. I only have a few pics, but we are working as on it as steadily as we can. I'll provide a full mod list including the suspension below, if you have any questions or comments pleast just post and ask them below!
1997 Camaro Z28 Modification List
Engine
Interior
Getting into the shop!
Before photo!
Passenger Side before photo!
Before photo driver side!
Stock opti and wires!
TorqHead 24x "the works kit", valve covering coil mounting!
Starting to put it together!
Getting there!
TorqHead custom PCM!
Putting in the OEM original harness! Car only has 75K miles so harness is still in excellent shape!
Finishing it all up!
Passenger side coils mounted!
Driver side coils mounted!
Shot from the front!!
Some more suspension goodies!
More suspension goodies! Anyone notice the power steering cooler mounted there by the radiator?!
Engine
- PaceSetter Coated Long Tubes (with AIR/EGR; have since deleted AIR)
- PaceSetter 3in ORY pipe (dumped before rear axle)
- Stainless Steel 3in band clamps used throughout entire exhaust system
- No Mufflers/Deleted Cats
- Custom Made Turn down before axle
- Full Lingenfelter Cold Air Intake “Super Tube Intake”
- Custom Z28 Throttle Body Plate
- 1LE Intake Elbow; non opti-vented
- SLP Throttle Body Airfoil
- Throttle Body Coolant Bypass
- MSD 8.5 Super Conductor Spark Plug Wires
- Torque Head 24x “The Works Kit”
- D585 Valve Cover Mounted Ignition Coils
- NGK TR55IX Spark Plugs
- Hi Temp wire Spark Plug boots
- Hi Temp cool Spark Plug wire socks
- RaceTronix 255LPH Fuel Pump/Hotwire kit harness/upgraded body ground kit/pump booster connector (use the pump as I would need it)
- March Underdrive Pulley on crank hub
- March Overdrive Pulley on alternator
- Chrome Billet Oil Filler Cap
- YoFab Fuse Box Cover
- BMR Chrome Radiator Cover
- YoFab Chrome Battery Cover (now powder coated gloss black)
- HiTemp cool sock wrapped fuel lines
- High Output Alternator (rebuilt to spec)
- High Output Starter (rebuilt to spec)
- Aftermarket Power Steering cooler (mounted in front of radiator)
- Custom tune by Moe Bailey
- Mighty Mouse Custom Made “DRAFT” Style Oil Catch Can Separator
- NITTO NT05; 275/40/17 front
- NITTO NT05R; 275/40/17 rear
- OEM GM Chrome SS 10-Spoke Wheels
- 1-inch Hub Centric Wheel Adapters for wider stance (rears only)
- Stainless Steel Brake Lines, full kit (front/rear)
- Black Powder Coated Front Brake Calipers
- Rotor Works slotted rotors (front/rear)
- HAWKS HPS front/rear pads
- Sam Strano Lowering Springs
- Bilstein HD Shocks
- Every mount or piece related to springs/suspension was completely removed and replaced with Moog or OEM Parts
- New Polyurethane Bump Stops (rear only)
- 99-04 Mustang Cobra Rear Spring Isolators
- UMI Upgraded Front Sway Bar with Energy Suspension Polyurethane Bushings
- UMI Billet Front Sway Bar Mounts
- Blaine Fab powder coated Front Heavy Duty Sway Bar Frame Mounts
- Energy Suspension Front Sway Bar Polyurethane Endlinks
- UMI 2-point Strut Tower Brace
- UMI 2-point Weld-In Boxed Subframe Connectors
- Sam Strano Master Cylinder Brake Brace
- UMI Tunnel Mounted Drive Shaft Safety Loop
- UMI Road Race K-Member
- UMI Upper Shock Mount
- UMI Upper Non-Adjustable A Arm with Delrin Inserts
- UMI Lower Single Adjustable A Arm with Delrin and Rod End
- UMI Delrin Power Steering Rack inserts
- OEM Inner and Outer Tie Rod Ends (both sides)
- Energy Suspension Polyurethane Motor Mounts
- LS Style “1-LE” Transmission Mount
- Poly/Roto Single On-Car Adjustable PanHard Bar
- Poly/Roto Single On-Car Adjustable Lower Control Arms
- Bolt-On Lower Control Arms Relocation Brackets (now welded on)
- Powder Coated OEM Upper PanHard Bar
- UMI Upgraded Rear Sway Bar with Energy Suspension Polyurethane Bushings
- UMI Billet Rear Sway Bar Mounts
- UMI Rear Sway Bay Over the Axle Mounts
- Energy Suspension Rear Sway Bar Polyurethane Endlinks
- UMI Full Length Adjustable Torque Arm
- UMI Transmission Mount Relocation Crossmember (automatic transmission)
- TA Performance Differential Girdle Cover
- TA Performance Rear End Main Stud Bearing Cap Kit
- Richmond Mega Rebuild Kit
- Brand New Motive Orange Box (3:73 Gears)
- Por 15 Gloss Black Painted Rear End
Interior
- Custom Made 30th Anniversary Camaro Dash Plaque
- Custom Made Z28 Metal Shift ****
- HAWKS Motorsports Rear Seat Delete Kit
- OEM T-Top Sunshades (1 set new in box and 1 currently in car)
- JVC Single Disk Head Unit with Remote
- Custom Made Mirror Chrome Camaro Lettering (rear)
- Custom Made Mirror Chrome Z28 Emblems
- Custom Made/Embroidered Cover-King Satin Stretch Cover
- Shorty Antenna
- 5% Tint on Rear Hatch and Sides
Before photo!
Getting there!
