on a 1996 Z28, anyone know the size and material for the two O-rings that are on the shaft on a Opti spark? This shaft is inserted into the end of the cam shaft. Thx all.
Don't those orings come in the timing cover gasket kits? Rock Auto has them for $7. You'd probably be better off just buying the kit to get the orings and having spare gaskets.
Pretty sure those are the ones you need at the very bottom of the picture.
If you are swapping out the opti, you should replace the opti oil seal and water pump oil seal in the timing cover. If thats the case just get the timing cover seal kit.
