Lt1 to ls1 spindle/knuckle question
Old Jun 21, 2019 | 08:17 AM
Fordtech's Avatar
Default Lt1 to ls1 spindle/knuckle question
I posted this in the suspension/brake forum but didn’t get any response. I have a 93 firebird and want to install a set of 00 spindles I have. My question is for the abs . The sensor plugs are different from each other. May I use my current wheel bearings on the newer spindles or do I need to get new 00 bearings and rewire/splice in the new sensors?
Old Jun 21, 2019 | 09:41 AM
seawolf18's Avatar
The wheel bearing was the same from 93-02. I swapped 98+ spendals and front brakes on my 96. The ABS plugs from the 98 parts was the same as my 96. If your wheel bearings are old I would replace them anyway, since you have it pulled apart.
Old Jun 21, 2019 | 09:49 AM
SS RRR's Avatar
Village Troll
If the hub fits snug into the spindle then I don't see why not.
Old Jun 22, 2019 | 03:31 PM
96Formula6spd's Avatar
When I swapped I think I used the 98 abs wire but only cause it was still attached to the 98 spindle.
Old Jun 22, 2019 | 04:40 PM
Fordtech's Avatar
as you can see the plug on the abs sensor is different as well as the wiring harness ends
Old Jun 22, 2019 | 06:55 PM
Must be a 93 thing. My brothers 95 and my 96 both plugged into the car side. I guess I was right that the hub side was different.
Old Jun 23, 2019 | 08:57 AM
Fordtech's Avatar
Will you look at your sensors please and tell me which one matches yours?
Old Jun 23, 2019 | 02:27 PM
Mine matched you 98-02 spindle on the left. It plugged straight into my 96 car. Brothers 95 was the same way. I think his came off a 00? but he has sold the car a couple years ago. Our body side plug looks like your 93 end. So I guess in 94? they reversed the connector.
Old Jun 26, 2019 | 08:57 PM
OnA Fan's Avatar
That's odd. I did my 93 and the connectors were the same on both spindles (like the one on the right in your photo).
Old Jun 28, 2019 | 12:50 PM
seawolf18's Avatar
Since the sensor is in the wheel bearing, just swap your 93 wheel bearing into the newer spindles.
Old Apr 4, 2025 | 07:15 AM
marc a's Avatar
Old thread, new question. When the "LS" spindle was swapped for the "LT" spindle did the toe need to be re-set?
I am about to swap spindles to do the CTS-V brake upgrade this weekend.
Thanks in advance.
Old Apr 8, 2025 | 01:52 PM
SS RRR's Avatar
Village Troll
Thanks in advance.
One hundred percent you must at least have the alignment checked after replacing suspension parts.
