4l60e
Old Aug 9, 2019 | 02:03 PM
fischdogg1's Avatar
Default 4l60e
Would a 1996 2 wheel drive tahoe transmission work on my 1997 trans am? I'd just swap out the servo's right?
Old Aug 9, 2019 | 02:52 PM
Gojira94's Avatar
Correct, 96-97 are directly interchangeable. Wouldn't hurt to swap out to a firmer 4th gear apply servo if the one from the truck is different/ softer. Tailshaft housing would need to be swapped over as well I believe. Might want to measure the output shaft from the tailshaft mating surface on the case to the end to make sure the output shaft is the same or wouldn't be different enough to cause an issue with the driveshaft slip yoke onto the output shaft.
