O2 Sensor Recommendations for Long-Tube Headers?
Old Aug 12, 2019 | 08:43 AM
Project_Daily's Avatar
Default O2 Sensor Recommendations for Long-Tube Headers?
Hey guys, I recently had an O2 sensor go out on my Firebird, reading very lean and making the engine buck and shake at idle. I replaced it with a Bosch from O'reilly's as it was the only fix I could get quickly, and it doesn't seem to be the right sensor for the application. I have an AFR gauge tapped into the left bank O2 (the one I replaced) and it usually shows running rich at startup which transitions into a swinging lean-rich cycle a couple of times a second. On startup, this sensor doesn't even register on the gauge it reads so lean, and doesn't start to approach stoich. until the engine's been on for a few minutes. In the meantime, the engine runs like hot garbage until the sensor warms up. So is there a sensor I should or shouldn't get? I noticed on Rockauto that the Bosch sensor was the only one offered for the car that didn't have a "perforated cylinder" styled sensor end. Is this just the wrong sensor for the application and it's not labelled properly? I ordered a Denso as a more permanent solution, planning to take the Bosch back. Any thoughts?
Old Aug 12, 2019 | 12:47 PM
BALLSS's Avatar
Get Ac Delco AFS 75. Amazon typically has them at the best $
Old Aug 12, 2019 | 01:55 PM
SS RRR's Avatar
Village Troll
Put a pair of Bosch on my car and they didn't even last a thousand miles before turning to ****. Have had Denso for the last two years without issue.
Old Aug 15, 2019 | 05:38 PM
KW Baraka's Avatar
AC Delco.
KW
Old Aug 16, 2019 | 02:25 PM
Viper's Avatar
I recently tried NGK 21006 after Bosch and ACDelco were slow - these run great
Old Aug 17, 2019 | 10:05 PM
Vicious95Z28's Avatar
I've only ever run Delco, I would probably consider NGK as my next choice.
Old Aug 18, 2019 | 01:31 PM
BALLSS's Avatar
Your running the "right" one now...why change to something that isn't?
Old Aug 18, 2019 | 05:46 PM
I'm not, I actually just replaced mine with new Delco's the week before last. Hopefully I'm good for a while. Occasional leaded fuel shortens the lifespan.
