Pulling out motor with basic hand tools...
Jacked up the car on all fours to disconnect everything that needed to be removed except the k-member bolts.
Once everything was disconnected I started jacking it up little by little inches at a time.
I did have to remove the front skid pad and disconnect the A/C compressor but could have been avoided if the back tires had been off the ground.
Time for the engine hoist. I'd already set up my connection point using tow straps.
Once again inches at a time using the floor jacks and then the engine hoist. I suppose you could use the engine hoist to support all the weight but I didn't and don't recommend it.
Once I had the car high enough I removed the hoist and positioned it on the side to help support the car in case the floor jacks and jack stands would give which would have done nothing to save the car but luckily the jacks and stands did their job.
I used two floor jacks on each side with wooden blocks and two sets of jack stands on each side. Call me paranoid but I still wasn't comfortable as it was windy the week I tackled this.
Had the blocks right there loaned to me by a friend but decided not to use them as the looked to be too small for my taste.
I did end up buying some tall stands for some added protection though.
