Procharger on high compression
Old Sep 2, 2019 | 06:02 PM
Alex-chevy's Avatar
Default Procharger on high compression
Hello
I've got a 383 with 12.5 compression. I've got Mahle Power Pak Pistons. Everything else is forged. Mahle told me I could run no more than 5psi of boost. I am assuming I would have to run only race gas though. Can the 4th gen F body's run race gas easily? I've got a Walboro 255 fuel pump in the tank. Stock fuel lines though.
Thanks
Old Sep 2, 2019 | 07:08 PM
Shownomercy's Avatar
Man-Crush Warning
Its not a good combo no matter how you cut it.
Old Sep 2, 2019 | 08:46 PM
Vicious95Z28's Avatar
Yeah I can't imagine trying to justify the cost of a blower and be limited to low boost. Pretty much a waste imo.
Old Sep 3, 2019 | 08:02 AM
moehorsepower's Avatar
^^^ Listen to what he says..
Old Sep 3, 2019 | 09:05 AM
SS RRR's Avatar
Village Troll
You want to do a power adder you'd be better off doing a wet kit.
Old Sep 3, 2019 | 02:38 PM
DAVE00's Avatar
I know it's not stock internals, but I couldn't resist!!!
Old Sep 3, 2019 | 02:51 PM
Kjduvall's Avatar
Take it apart, change pistons/cam. Stud mains/heads then go have fun... Just my simple answer..
Old Sep 3, 2019 | 03:13 PM
Kjduvall's Avatar
Ooh and don't forget to gap the rings (loose) /pull timing/colder plugs/ and over build the fuel system.............. How could I forget that?
