Solid roller guys come in please
I'm curious if any of you SR guys have run into this and if you found any ways to improvise? Lloyd said that using ARP bolts would be sufficient but I'd personally still prefer studs. If any of you guys have any insight please lmk.
Thanks, James.
For what it's worth, I used the bolts instead of studs because the motor was subject to tear-down on demand and I was never sure that I could pull the head off underneath the windshield cowl when using studs. A 4th gen F-body isn't the easiest car to work around.
Good luck,
c
