97 lt1 keeps turning off
Old Oct 15, 2019 | 07:39 PM
Johny956's Avatar
Default 97 lt1 keeps turning off
He guys’d I bought a 97 transam lt1 it's cause mine I changed the fuel pump and started and ignition coil and fuel filter well it's runs fine and everything but when the check gages light turns on the car turns off automatically and it takes a while to turn on or I gotta wait or keep on trying but once it takes off check gauges it turns on, I need help putting to much into this car
Old Oct 16, 2019 | 11:41 PM
KW Baraka's Avatar
Originally Posted by Johny956
…...well it's runs fine and everything but when the check gages light turns on the car turns off automatically and it takes a while to turn on...….
Check for antifreeze/water in the engine oil....it would be looking like sour chocolate milk.
When my car did this several years back, I had a blown head gasket.
Best of luck!
KW
Old Oct 17, 2019 | 09:49 AM
SS RRR's Avatar
Village Troll
https://ls1tech.com/forums/lt1-lt4-m...e-running.html
Old Oct 17, 2019 | 11:11 AM
hokeplaya05's Avatar
terrible grammar + multiple threads on the same thing + recent join date = TROLL
Old Oct 19, 2019 | 11:09 AM
Phoenix'97's Avatar
Get yourself an OBD-2 scanner to find out what codes you have. From there you will have to look them up and try to narrow down what is wrong with your car, assuming the problem is not so big that you simply don't have the knowledge and tools to do it yourself. Furthermore, give your EGR valve a check and make sure it is not sticking or stuck. My 1997 Trans Am was running for a long time with a bad EGR valve since it never gave any bad indications but it needed to be replaced. It is always worth a check and might help remedy or narrow down problems with your car. OH YEAH, there are two different EGR valves for manual and automatic. Make sure you specify and verify you have the correct part!
