93 z28
I've got the same issue the OP has but for a different reason. I was removing wires no longer used in my harness and may have cut the single wire that leads to the PCM way up in the harness and then rewrapped the harness. Grrrr...but I can't say for 100% certainty it was the tach signal wire. I'm old and memory wanes me. Looking at the old XFI install there's mention but doesn't give me the pin out so I how I did it and had it running is beyond me. But if I find where the single wire runs to the PCM I'll be sure to post it.
OP after a little digging on the PCM connector pin A-12 is the ignition control and the single white wire. Granted it doesn't say "Tach Signal but if you look at Shoebox schematic for instance where it shows the opti and all the wires associated with the ignition control module harness. That white wire leads to there then onto the tach filter then onto the back of the dash to the tach which is a single white wire.
🖕🖕🖕😁 now i must apologize to anyone else for offensive or rude behavior.
