High amp alternator
Old Jan 11, 2020 | 06:24 PM
Alex-chevy's Avatar
Default High amp alternator
Has anyone run a 170 or 200amp alternator in their F body without making any wiring changes? Is it nessesary to make any wiring changes with a high amp alternator in our cars?
Thank you!
Old Jan 11, 2020 | 07:48 PM
Shownomercy's Avatar
Man-Crush Warning
Thank you!
It would not make sense to do so, but yes you certainly could.
Old Jan 11, 2020 | 08:04 PM
Alex-chevy's Avatar
I read somewhere that you need to upgrade an ignition wire of you up the amps on the alternator.
Old Jan 11, 2020 | 08:28 PM
B52bombardier1's Avatar
The devices on your vehicle only consume their same number of amps if you put in a higher capacity alternator. The two biggest reasons to ever upgrade an alternator would be a new high wattage car stereo or maybe a change to electric radiator fans. At that point, you would need suitably fat gauge wire for those items and probably a fatter 12 volt positive wire out of the alternator towards the fuse block.
Rick
Old Jan 12, 2020 | 07:43 AM
Man-Crush Warning
I do not believe that will do anything.
I have a 200 amp unit in my car with factory ignition (sense/POR) line but with a 0 gauge wire to battery now. If you want to have full use of the 200amp source you will need to upgrade factory wiring IMO
Old Jan 12, 2020 | 08:04 AM
Alex-chevy's Avatar
Thank you
Old Jan 12, 2020 | 09:25 PM
383z's Avatar
The Big 3 mod is easy.
Old Jan 24, 2020 | 02:29 PM
Blackbirdws6's Avatar
Better cables won't hurt but why are you going for HO? Also when selecting a new alternator, make sure you get the right size pulley.
