What makes the Brake light come on?
Ebrake switch is working properly at switch. Full on fluid. Brake lights are all good. Calipers are good, hub bearing/speed sensors are good.....
What else is there? Occasionally ABS INOP comes on, but haven't been able to diagnose it because code readers keep failing to connect unless light is off. But then fails to connect when trying to see code history.
What all triggers the BRAKE(P)(!) light to come on?
How do you know all of what you mention is good w/out being able to complete scan? If the INOP light triggers while the car is in motion that usually leads to a bad wheel sensor.
I was able to get it to read once, but I forget exactly. I pressed back on accident, and then couldnt get back to it. Something about right side dump, or along those lines? Buddy suggested ABS module is going bad, will this trigger the Brake light, or only the ABS light? I havent found any replacements, or anyone to rebuild them in the event I need to replace it. What are my options there? Used would be too iffy I imagine, but might be only option.
Brakes feel fine, stop hard, and give me no feedback issues. Traction control kicks on if I stop hard on wet surfaces, Im just really ******* tired of that red light always on. ABS light is intermittent, and doesnt always come on. Ive gone a few days with it off. Hard to verify exactly when it comes on, but seems to be triggered during breaking if Im paying attention correctly. Goes off when I kill it, doesnt always come back on. Sometimes has come on right away.
Ive been thinking ABS and Brake light are mostly independent. I guess I need to know if they are or not. Thatll certainly narrow it down.
I haven't had ABS on mine since 1999 when I went with a 12-bolt. ABS light still works!
Gonna go look at different methods of bypassing the ABS stuff.
For the ABS module, there are something like 20 codes that will light the red warning lamp. None are associated with the wheel speed sensors. ABS control module itself, ABS enable relay/wiring, or the actual ABS motors/solenoids or wiring. Hopefully you can pull the codes.
Hope this helps -
Jim
Hope this helps -
Jim
Thanks for that guys. Gonna poke around see if i can find any shorts. Now, all my lights dim when i hit the brakes. Was thinking about doing Big 3, but really need to verify if any shorts present. I haven't seen anything yet, but haven't specifically searched yet.
They had wired in a flasher setup for the rear brakes to blink like the mustangs when blinker is on. Was a **** job, but i put everything back to stock and didn't have any other issues. Maybe something happened..
My rear hatch works, are these supposed to pull it down like the later 3rd gens? It doesn't do that. I gotta hit the button a couple times and pull up onnit.
"The red "BRAKE" warning lamp will be illuminated when a low brake fluid level in the master cylinder is sensed, the parking brake switch is closed, or under control of the EBCM when certain ABS codes are set. This lamp indicates to the driver a base brake problem may exist." - Out of the service manual. 93-97 cars don't have a low level sensor, so don't bother looking for one.
I've gone to O'Reilly to borrow their ABS scanner before, see if yours will let you do that. Some ABS scanners don't work on our ABS system because it's so old and finnicky, just something to keep in mind. You can also buy a cheap ABS scanner off the interwebs, just make sure they say it will work with our cars.
