Pulling timing for Nitrous on LT-4
Have an old NOS fogger plate, max 150hp. Sent it to Induction Solutions for blue print and flow. Need to figure out if there is a good solution for pulling timing only when on the bottle. I can tune the timing map to accommodate, worse case scenario, but then I have to drive around daily with that. It has a brand new Opti but otherwise stock ignition.
The FAST made it much simpler with a crank trigger.....and a true distributor like what we all ran..
